- Connecticut
We should start keeping track of the error codes and what they mean.
Code 007 - Battery isolation -- Reference: Code 007 isolation
Code 32 - Service Required -- Reference: Error: Service Required Neg Weld
Code 33 - Service Soon -- Reference: Warnings on dashboard on new MXR
Code 34 - Service Required -- Reference: Error: Service Required Pos Weld
Code 35 - Service Soon -- Reference: Display Functions and Firmware Version
Code 36 - Battery Fault -- Reference: Code 36 service required??? Per ex-Alta employee "It's a voltage imbalance within one or more of the battery modules. It indicated a possible interrupted connection between cells, a fault within the battery itself."
Code 37 - High humidity within battery pack -- Reference: code 37 high humidity in battery pack
Code 103 - Battery won't charge -- Reference: Alta Fast Charger, and also 2018 Alta fault code 103 second time
On the Display - Negative Contact Relay Failure -- Reference: MXR Negative Contact Relay Failure
On the Display - Cycle Key To Erase Battery Error -- Reference: Cycle Key To Erase Battery Error
On the Display - External Charger Fault -- Reference: External Charger Fault???!!!
On the Display - Inverter Throttle Fault -- Reference: Inverter Throttle Fault
On the Display - Service Required Pos Weld -- Reference: Error: Service Required Pos Weld
001: Complete
002: Start Timeout
003: HVIL Cancel
004: DC Disconnect
005: Soft Stop
006: Charger State Error
007: Isolation
009: Charger port wet
101: Positive Relay Welded
102: Negative Relay Welded
103: Precharge Failed
104: No Proximity
105: AC Cable Disconnect
106: Internal Comms
107: Chassis CAN Timeout
108: Temperature High
109: External Comms
110: External Fault
111: Shutdown Timeout
112: Internal Voltage Low
113: DC Timeout
114: Boost Fail
115: Negative Relay Fail
116: AC Relays Welded
117: AC Relays Fail
118: Ground Absent
119: GFI Trip
120: GFI Reset Fail
121: GFI Test Fail
122: AC Voltage Low
123: AC Voltage High
124: Control Failure
125: Sensor Failure
001: Complete
002: Start Timeout
003: HVIL Cancel
004: DC Disconnect
005: Soft Stop
007: Isolation
104: No Proximity
106: Internal Comms
109: External Comms
110: External Fault
113: DC Timeout
114: Boost Fail
117: AC Relays Fail
118: Ground Absent
119: GFI Trip
120: GFI Reset Fail
121: GFI Test Fail
122: AC Voltage Low
125: Sensor Failure
