- Temecula, CA
External cooling of the pack will only help so much. In fact, i plan on doing back to back tests with my mister fan to see how much of an effect on battery temps externally cooling the pack actually makes. @Mark911 said he had cooled wet towels blanketed over the pack when he was having a pro ride his bike for slamfest a few years ago, and it didn't help all that much. In my experience, though, externally cooling the pack does help lower the temps a little bit. I'd like to quantify the effect via MultiTool, though.
What would really be awesome is if we could redesign the battery packs to allow for actual cooling of the cells inside. Mark's idea was to pipe cooling channels weaving in between the cells, a la Tesla. You'd have the loop exposed to the outside of the pack so that you could hook up water lines to it. The idea is that you'd "precool" the pack before a ride to give yourself a higher thermal ceiling, of course draining the system before you ride so that you do not carry around all that water weight. If you start off cooler you'll be less likely to heat the pack up to the thermal limiting temperature of roughly 70*C.
I got into reading more about cooling 18650 cells and it seems like the most efficient way is to cool the end terminal tabs of the cells rather than the sides of it. To this point, perhaps we could simply fabricate a water block that lays on top of the PCB that has individual heatsinks down pressing on each cell terminal. We'd have to be very careful not to cause a short, though.
