Throttle Connector Pinout
chrisflysit
I'm looking for the pinout of the throttle connector. It looks like an 8-pin connector with 6 locations populated. Just knowing the power and ground pins would be a big help.
There is a break out of the CAN_LO and CAN_HI which splits out PWR and GND. Soo... Pin (1) and Pin (4) (Silver row, with Pin 1 on top) are PWR. GND is Pin (2) and Pin (5) (on top of second row).
Did you crush the JST housing?
Reactions: #76
chrisflysit
Thank you for the help. I plan to use the throttle on a another bike. I got to spend some time on my friend's Alta and really like the throttle.
chrisflysit
Thank you.
Just a quick note for anyone looking at this in the future:
For some reason when you copy and paste from that PDF it gives you the wrong part number. (a 4 pin)
The 8 pin connector housing is 08R-JWPF-VSLE-D to mate with the throttle.
chrisflysit
Based on the first comment from Rashid510 (see above)
Pin 1 5v
Pin 2 Ground
Pin 3 Output 1
Pin 4 5v
Pin 5 Ground
Pin 6 Not Connected
Pin 7 Not Connected
Pin 8 Output 2
But I have not tested it yet.
