Stark Varg charger housing kit
Swank171
Does the OEM stand (without the charger) flex a much when putting the Varg on it?
I use a pop up stand so I’m not heaving this thing up on a stand every time I stop.
I haven’t tried the stock stand without the charger but i imagine it wouldn’t work very well….im sure it would be easy to throw a crossmember in there to get that support if you really wanted to use it
gewoontim
The Netherlands
Is there anyone from the US, UK and Switzerland who can measure the diameter of their wall power cord? I want to make sure the diameter is the same as the EU plug. Thanks!
I'm in the US, and my power cable is .37" diameter over the outside insulation.
The 3 wires inside the power cable were stripped and tinned with solder, I'm guessing from memory that they are 14 or 16 gauge.
And the black wire is the ground, white and green are what we would call L1 and L2.
Is this a standard European color scheme?
Here in the US, green is ground, white is usually neutral on a 120v circuit, and black is "hot."
But since this is primarily a 240v power cord, green would still be ground, but L1 and L2 would normally be black and red.
Hope this info helps
gewoontim
The Netherlands
To make things a little easier, I have created a Google Forms where you can enlist for the next batch. To everyone I am already in contact with: you don't need to fill it in, I have enlisted you already in this list.
gewoontim
The Netherlands
Very nice.. Any cases left?
To be honest, the demand is quite overwhelming haha. I will be making a plan to make some more, so you can sign up and I will keep you updated!
For the others who have received their kit, please find attached the quick assembly instructions. I will be making a video walkthrough as well, but this should be sufficient to assemble the kit.
  • Stark housing kit - Assembly instructions.pdf
erSitzt
A little advertisement für @gewoontim `s work ;)
Great idea and solution for a charger housing! All 3D-printed parts look amazing, everything is a snug fit. Would definitely buy again... 🥳
...and i think Tims cooling solution is even better ( placement of the fan )
gewoontim
The Netherlands
Am I in this batch?
Thanks!
Hi Josh, sorry for the late reply. But not yet, you are in next batch!
Thanks man! I also put way too many hours in perfecting the design to make it fit perfect and be easy to assemble, but I hope the end result is worth it. Glad you like it!
For everyone else, I have ordered parts for 10 more kits. The KTM dealer was curious as they thought I made a mistake in ordering so many charger housing parts :LOL:.
