Button Unit get Stuck with dirt, Varg EX and MX
airmartl
With mud or with fine dust/sand the buttons get stuck. is there any solution?
I think the old MX bike are directly hard wired and the people can build own buttons, right?
But the EX has a CAN Bus circuit board inside the button unit - thats not possible to replace or does someone know the CAN IDs?
Thanks
Only had it once and i do 99% mud and sand.
Closed handguards are a good protection since in a crash you don't dig in so deep.
Also be spray a lott of PTFE spray all over it, less sand sticking is less sand getting in.
UKLee
Stark have sent me 3 new units under warranty each time with the promise there was a re design in the pipeline, then started saying you have to strip it down and clean it as part of the service, what use it that when it sticks in the middle of nowhere and leaves you stranded.
I was shocked to see they use the same buttons in the EX unit.
Thanks
I have replaced many button units on the MX. I use my bike for enduro and have dropped the bars into deep mud and dirt and it has caused problems. Sometimes you can use a thin piece of wire to clean around the edges and free a stuck button other times I have been forced to push because a stuck button can leave you DOA...
If I had more time I would design a thin rubber boot to encase the button unit similar to what the Japanese bikes have. My WR450f button unit is 10 years old and I have never had a single problem and I have submerged that thing in muddy wet goop many times.
I agree with @UKLee I was surprised they used a similar unit on the EX. The Stark guys are Euro-geeks wanting uber clever. We know the buttons can do cool shit but you gotta remember to keep it functional. Ya a rubber boot would reduce the "geek cool" but you gotta remember the use case. :ricky:
Believe it or not, Silicon Toe protectors do the trick. The Silicon is stretchy enough to become almost clear to see the buttons, but unfortunately the life span isn't great when stretched that much. But for power washing or a mud race this should be fine.
airmartl
Ahahah it's amusing that, once installed, it fits so neatly that it looks like a dedicated aftermarket accessory.
The only possible problem that I see is what I illustrate in this picture that I got by playing with the contrast of @AL_V's picture:
I think it's a possible problem, so surely I don't want to discourage people from solving an issue with a simple and cheap solution that someone has already used successfully, just if you see the bike behaving oddly, remember that maybe it's the toe protector pressing a button.
That is a good point. On my Yamaha the rubber boot that protects the switches is formed to prevent that. Nevertheless, I am going to try the simple fix. As it is I have found the buttons on the MX can be somewhat flakey --especially when transitioning drive modes between crawl, reverse, and drive.
This does NOT seem to be an issue, you can feel the buttons depressing and returning thru the rubber.
I don't see this being a problem, but appreciate your observations.
Nope, you should have ordered the "small" size (not pinky, just small).
I was at walmart today and got these Zentoes, 2 pcs for around $6, and they fit the MX nicely.
Amazon gives you 10 for $10, so that's a better choice.
Thanks to @drehwurm68 for the idea!
I wouldn't recommend the brand in the Amazon link. If you read the description it mentions moisturizes but is not really clear. However, they are infused with aloe vera it smells and I don't think the switch needs to be moisturized... :muutt:
