No special tools needed, it is very easy, just loosen the 2 notched preload rings all the way, and it becomes obvious how to remove the spring seat. Like everything else, there are youtube videos.
I swapped my rear spring last weekend without any extra tools.
Just removed the 2 bolts holding the rear shock, and removed the shock from the top. Pushing the subframe slightly to the left side you get a nice space to pass the shock.
