Gone 2018 Alta Redshift EX - dual-sport road-legal electric dirtbike. $8,900 OBO
flask38
Provo, UT
Have a chance to own the pioneer in the only proper electric dirt bike on the market with proper frame, suspension, brakes and the lateral grip missing from all other manufacturers (with the exception of the new Stark Varg for $15K).
All electric means no engine rebuilds, oil, clutch (this is direct drive - one gear) and maintenance. Just charge and go!
This is a dual-sport road-legal electric dirtbike. Bike rides perfect. Battery still feels like new. All maintenance performed (i.e. coolant change, gear-reduction oil changed). Always stored at 60% charge when not in use to maintain longevity of 5.8 KW/h battery.
Range for single-track up to 20MPH is about 6 hours of actual riding time
Comes with 110v or 220v charger
Range goes down for higher speeds
174 ft/lb torque via gear reduction to back wheel to about 47 HP
Upgraded Dal Soggio fork drop-in kit with full adjustability
Ride sag set for 180 lbs rider +- 15 lbs
New (one ride) front Dunlop Geolander and rear Shinko Cheater tire (extra soft) & tubes
Spare parts (new) included with the bike:
Skid Plate
Kick-stand assembly (complete)
throttle tube
left and right turn signals
left and right upper fairings
number plates
lower chain slider
drive mode switch
Original tail section, rear light, and license plate assembly included
Title in hand. $8,900 OBO. Bring cash if you would like to take it for a test-ride. In Lindon, UT.
New Rage Cycle rear license plate bracket is slightly bent (aluminum) and LED lights are on the bike now.
