For Sale 2024 MX
MadpdXabbott
Silverlake, WA
6,900 O.B.O
2024 MX Senior owned still under warranty till march26, no issues. always hand washed.
Rear wheel size: Enduro 18"
Side stand: Included
Suspension for your weight: Hard 90-100 kg
Body color: Snow White
Power: Standard 60hp
Rear brake: Hand brake
FEATURES
THE MOST ADVANCED ELECTRIC MOTORCYCLE IN THE WORLD: With 30% more power than a traditional 450 combustion bike the Stark VARG outperforms all other bikes on the market.
LIGHT AND AGILE: With the lightest motocross frame on the market, the lowest centre of gravity and an optimized weight distribution the Stark VARG provides agility and a featherweight riding sensation.
938 NM & 14200 RPM: The Stark VARG delivers an incredible 938Nm of torque on the rear wheel and the carbon fibre sleeve motor spins at up to 14200rpm.
+100 RIDE MODES: The Stark VARG is equipped with an Android Stark phone that allows you to customize the bike, adjusting the power curve, engine braking, flywheel effect and traction control, to make the perfect bike for every rider and track.
6KWH UP TO 6HRS OF RIDING: The 6kWh of the Stark VARG allows you to ride for up to 6 hours of easy trail riding or complete a full MXGP heat and recharging takes between 1 or 2 hours depending on the outlet and charger.
RIDE ANYWHERE, ANYTIME: The Stark VARGs near-silent motor allows you to ride anywhere, anytime, letting you ride in places youd previously never imagined possible.
ZERO EMISSIONS, LOW MAINTENANCE: With zero emissions and no filters to change the Stark VARG requires a very simple level of maintenance. Its as easy to take care of as a bicycle.
