Slayer
- South Chicagoland
For those considering the LHRB option from Alta Motors
Download the PDF file below.
After doing my install, felt I would have wanted to know what was involved prior to my purchase. There are a couple of things to watch out for with the items in the kit.
1.) The clip that is provided for mounting to the motor needs to be snipped or ground down to fit the bolt gusset on the motor.
2.) On the EXR the routing of the brake line through the headstock needs to be carefully considered.
3.) The sleeve on the brake line that is for protection against the swingarm and motor needed to be moved forward to cover the contact point of the cable at the top of the gear cover. (This would most likely be best accomplished prior to final mounting and connection of the banjo bolt.
4.) On the EXR the former foot brake electrical sensor wire and clip need to be addressed to protect from moisture and just dangling there. I used black tape to cap the clip and a zip tie to secure it to the neighboring wire.
