HadesOmega
- San Jose
Saw this on charged cycle works store. Its available now and it's street legal. Looks kinda like a 250cc size trail bike. Can't help but think it looks similar to another bike...
chargedcycleworks.com
Copied from Charged Cycles Works description:
72v 73ah (5.3 kWh) is one of the largest OEM batteries we've seen, perfect for getting you in and out of the backcountry with zero range anxiety.
25kw That's more than you need, but nice to have when you want it. Multiple power modes allow you to ride slow, safe and controlled or have some fun when you want.
18/21" wheels for easy roll-over on tough terrain and an extended skid plate for protection.
Street Legal Kit complete with high/low beams, hazards, and turn signals. Remove them if you want, or ride wherever you want, whenever you want.
Modular Rack System for accessories, with even more in the works and coming soon!
Nearly Silent drive train. No noise and no smell to scare off wildlife. This is a hunter's dream but also the perfect trail bike.
Camo Edition: We do not uncrate and wrap each bike, but the camo wrap is included. It's easy to install and will last years.
Built for the serious off-road enthusiast, this powerhouse harnesses cutting-edge electric propulsion that leaves traditional vehicles in the dust. The SD upgrade delivers a significantly larger battery capacity, integrated blinkers and mirrors for enhanced safety, and our signature modular rack system that's consistent with our other SD models. With industry-leading range and performance, the Puma X22 SD transforms impossible trails into your personal playground.
-Advanced battery system for extended range
-Enhanced suspension system for superior comfort
-Modular Rack with Quick Release System
-LCD display screen
-Industry-leading US-based customer support
[td width="316.812px"]DISPLAY
LCD Screen[/td] [td width="316.812px"]BRAKES
Front & Rear Hydraulic Disc
Copper Base Brake Pads
Breakaway Brake Levers[/td] [td width="316.812px"]FRAME
Metal Q345B+6061 Forged Aluminum Alloy[/td] [td width="316.812px"]TIRES/WHEELS
Front Tire: 80/100-21
Rear Tire: 110/90-18
7116 Alloy Rim, Casted Hub[/td]
[td width="313.156px"]MOTOR
Peak Power: 25,000 Watts
Peak Torque at the wheel: 850Nm[/td] [td width="313.156px"]TOP SPEED
77 mph
0-62mph: 5 seconds[/td] [td width="313.156px"]WHEEL BASE
56"[/td] [td width="313.156px"]
DRIVE SYSTEM
Automatic CVT with Reverse Gear
[/td]
Camo Edition Bakcou Puma X22 SD Electric Motorcycle
Puma X22 SD eBike – 25kW peak, 72V 73Ah battery, 77 mph top speed, hydraulic brakes, extended range, modular rack, and off-road ready.
Description
Let's start with the specs that really matter...72v 73ah (5.3 kWh) is one of the largest OEM batteries we've seen, perfect for getting you in and out of the backcountry with zero range anxiety.
-LCD display screen
| THROTTLE Twist Throttle |
| SUSPENSION MNT Single Cavity Double Adjustable 84mm - 250mm |
| STEERING PROMAX Wide 760mm Handlebars with ergonomic locking grips |
| OTHER COMPONENTS Extended Skid Plate, Modular Rack System, LED Headlights, Blinkers, Mirrors |
| BATTERY 72v 73ah Lithium Ion |
| CHARGE TIME 2hrs (40A Charger) |
| GROUND CLEARANCE 12.5 inches (without rider) Seat Height: 35.4 inches |
| WEIGHT 285 lbs |
77 mph
DRIVE SYSTEM
[/td]
