Cake suspension thoughts
Can you elaborate on why the Cake wasn't for you? What makes the Suron better in you opinion?
Number Six
Midwest
Doubt you'd be able to get those custom Ohlins without buying a Cake ..
Have seen some highly modded Surrons with the 43mm WP forks from the KTM SX85. 2018 & later are the air forks I believe. ( there's a set of 2021 SX85 forks on eBay currently )
You could also get the Ohlins STX 22 closed cartridge kit & install into the open chamber 43mm WP outers of previous years.
You'll likely need to be swapping out everything with a fork change ; triple clamps, wheel, brakes & so on.
link for the adaptor to fit WP forks on a Surron ; GritShift Big Sender 85 MX Fork Conversion Kit
