Charging - 220 vs 110
DirtSurfer
Portland, OR
I don't (currently) have a 220v "quick" charger set up in my garage.. instead, I've been plugging my PHEV car into a 110v household socket, which of course takes forever, but it works.. (I just leave it plugged in over night).
The Varg EX mentions having a 220v adapter as standard, w/ a 110v adapter "available" (likely for a fee).
Curious what folks experience is w/ all this, contemplating just putting a 220v in the garage to support both use cases..
Thanks for the input!!!
joer
Ottawa, ON
I find it’s handy to have at times. I generally will charge up to 80%-ish overnight and just top up before I leave for the track.
At 240V, you get about 1% a minute, give or take. (The EX may be slower since the battery is larger.) At that speed, it's reasonable for me to get home from work and finish the charge while I get changed and load up the car.
Also, when I get home from the track, I can throw it on the charger and in fairly short order get the battery back above 20% if I happened to drain it way down that day.
Just speaking from my experience at an MX track: Having 240V track-side charging is a huge plus and makes the bike really easy to live with. I tend to use a bit more than one battery's worth of riding on most days (before my body wears out). If it's quite muddy, the battery drain is noticeably faster. I think it would be less pleasant if I was limited to 120v track side charging.
DirtSurfer
Portland, OR
Do you use a generator for track charging? (If so, what do you use, and does it work well?)
joer
Ottawa, ON
No generator. I went kind of over-board and did this:
That said, it's working really well and comes in handy during the off season if there's a power outage. Or at least, that's how I'm justifying it to myself. :)
The LiFePO4 batteries I recharge with a 120V charger (15 Amp) and they will comfortably charge over-night. I'm not nearly as careful with those.
Yes the Stark chargers come with a 240v plug. They sell a 120v adapter, for use in a 120v outlet. Max charge rate is about 1,600watts on 120v and 3,200watts on 240v.
Having a 240v charge source is great if you forget to charge the bike or need to charge it fast, but most of the time, it's better to charge at a slower rate. But you can do that even when using a 240v outlet by setting the charger rate slower via the apps. Meaning, 1,600watt charge rater is 1,600 and doesn't matter if you are using a 120v outlet and charging at max (for 120v) or plugged into a 240v and lowering the app from the 3,200watt charger tater to 1,600watt charge rate. Meaning, there is no downside to having a 240v outlet available. With that, you can charge fast or slow. Only the expense of the install. And it will be handy for your PHEV.
Research what 240v outlet to use. There are many instances of a 240v outlets melting even when used within their power rating. This because EV use was never imagined with them. Typically it's stoves or dryers, etc. Not pumping max rate through them for 5+ hours straight like with EV. The Varg won't draw enough to worry about it, but your PHEV might. A BEV definitely would, so might as well future proof it and get a good heavy duty 240v outlet from the start so you don't have to replace it all later if you get a BEV.
DirtSurfer
Portland, OR
fantastic, thank you!
FYR
Central Valley, CA
Stark supplied a 120v adapter with my 2024 Gen 2. Very good quality piece, actually. If I were to guess I'd expect that the new EX bikes will deliver with one as well.
Most dealerships were not provided one with the bike, so buyers were not either. but dealers had them for purchase. My dealership made me buy one from them.
Curious if all, that received the bike directly in the U.S., got the 120v adapter for free? Or free if you asked for one? or if some direct delivery buyers had to purchase it, too?
svtride
DEETROIT
Dealer I ordered my EX from last month had 3 MX’s sitting on floor on their charge stands…pop the charger doors open on all of them and the adapter cable fell out . Salesman said the adapters came with bikes and looking closer the adapter was manfactured by same supplier as the 230v cable comming from the charger. EX quoted to me as identical as if I order via internet with home delivery.
Sounds like the info I received from my dealership was suspect (that the bikes they received didn't include the adapters). Ah well. They gave me such a huge discount on the bike and swapping on the tubes/tires I wanted, that the $30 adapter "is but a pittance" of the overall deal. Ha.
I didn't receive an adapter when I picked up my bike around May 1 2024.
I should have asked for one, but just made my own for about $7 with an Amazon female L14-30r.
Also, when I got mine, the charger had the removable type plug (not the molded plug they are shipping now).
