charging complete?
Bionicman
E powertrain proponent
WA
will the bike display report once charging is complete?
it seems when charging my bike battery display shows full but 'charging' is still displayed for quite some time - so went riding.....
The pump keeps running to cool the battery and even out the internal heat that was caused by the charging. Let it do its job, if you are not in a hurry.
I thought we established that there is no coolant circulating in the battery...
metallic88
utah
there is no coolant in the battery, and due to that the heatsink on the a battery gets really hot while charging Ive been thinking about putting a fan on there(or milling a better heatsink to attach to it), the r battery looks like they use a bigger heatsink. the coolant keeps the electronics(inverter etc) cool since they're running to keep an eye on the battery. but for the original question yes if the key is on the display will say charging is done and then everything will be quiet like before you turned it on.
Bionicman
WA
For reference, it is normal for electric vehicles to "keep charging" even though the pack seems to be full. In general, vehicles will balance the pack, run diagnostics, etc... during that time.
Sounds important think I’ll cool my jets next time
strider
NE Oklahoma
Well, don't let it spoil a ride. You definitely need to let it sit and balance sometimes but not every time. You should have no qualms about halting it mid-charge or at the top of a charge. The BMS can handle it no problem - it takes numerous cycles to start getting out of balance and such. Just whenever you get back and settled (like on Sunday night) let it do a full charge and let it sit to balance.
Bionicman
WA
To answer my Question charge display on the screen briefly displays charging complete then shut down ha ha and youll also noticed the fan on the charger inverter turns off
