coolant procedure
fsfs
HRV
Has anyone asked which coolant is recommended? OAT, HOAT, or products like Engine Ice, ect?
From the IGBT module literature:
The pin fin structure is suitable for cooling fluids like water/ethylene glycol mixture
Coolant fluid with its corrosion protection has to be compatible with the aluminium of the cooler material
and the nickel overplated Cu module baseplate
Typically BASF Glysantin™ G30™ with an organic-acid-technologie (OAT) silicate-free corrosion
protection is applied.
HadesOmega
San Jose
Here you go straight from the manual. I have yet to do it myself looks like the previous owner did it already. 100 hours seems like a short interval, these coolant last for a very long time. I believe there are testers you can use to check the state of your coolant. Manual also states 50/50 Prestone Coolant.
