Dolly Towing with SXS
privateer703
AOF Addict
Altoona, PA
So since I've decided to go on this Hatfield-McCoy trip I would like to tow the Alta with the SXS with something like this:
Tow Dolly
I would look at something beefier, but the Rzr has the small hitch, which I don't think is a big problem, the Alta is relatively light. I could strap the handlebars to the Rzr's roll bars to help stabilize it, however at the bottom of hills or at incline changes that strap will either go slack, or get over-strained during those changes. The tow straps mostly relieve any stress on the swingarm and front forks on camber, so if you remove them you than have that. So I figured that the Alta hand to be strapped to the tow dolly only, and at the center of the wheel axles so the strap geometry never changes. Oh, btw, then it also has to be gimballed for camber. Now it gets complicated.
While you ponder that, also consider I posted this some time ago, just as humor:
Haul it AND Charge it
