Want to buy EX / EXR/SM Lower Headlight Mount
VINSANITY
Looking for the stock lower headlight mount for an EX/EXR/SM.
Liquid only has upper mounts to my knowledge.
Looking for the stock lower headlight mount for an EX/EXR/SM. Liquid only has upper mounts to my knowledge.
You might want to give them a shout to check - as of late last year they still had unlisted parts. I was looking for the rear brake line holder and they made up an ebay auction immediately for me, worked out great.
Ancient history maybe, but Liquid now has SM lower headlight mounts in quantity. These are different from the EX/EXR, pics below (MXR on L, SM on RH top, EXR RH bottom) & in eBay listing:
The SM and EXR brackets look nearly the same to me except for the fender mounting 'ears' in the middle. If the MXR bracket (which is basically just the ears, fender locator stubs, and crossbar etc.) could be piggybacked on top of the SM bracket - I checked the screw-hole spacing, looks identical - it seems like it might work for the dirt bikes. The fender holes might need 2mm or so of elongation to the front. Hopefully one missing part of the EXR-conversion kit available again.
