EX Kill switch behaviour
Hinkelstein
Here in Europe the EX doesn't come with the kill switch on the right side.
So I asked SAM about what it does, answer:
When you press the kill switch on the Stark VARG EX (as equipped for the USA), it immediately powers off the motorcycle. It does not simply switch the bike to neutral; instead, it cuts power to the motor and disables the bike for safety. This is a hard cut-off, intended for emergency use, and is not the same as switching to neutral mode via the control switch.
For normal operation, you can use the On/Off button on the control switch to turn the bike on or off, or use the neutral mode for disengaging the throttle. The kill switch is specifically designed to instantly power off the bike.
If you have further questions about the kill switch or other safety features, please let us know.
So I ordered one, installed it and must see it behaves EXACTLY like the red button on the left side. So how is it working in US? Is SAM right and is there a real difference between US and EU Bikes?
SAM isn't always up to date - maybe it was originally intended to work like this but hasn't made it into production (yet)? Shane Pinney mentioned it in one of his first EX videos on YouTube - works in the US just like you described.
FreddyFugazi
BVT
haha I (who has the US model) just realized I haven't touched the kill switch since I adjusted its position during assembly. I just checked the manual and it does indeed seem to be a redundant way to turn the bike off. I assume its for the same reason we need big ugly blinkers. We have a lot of outdated rules and regs regarding motor vehicles.
