- Lake Havasu City, AZ
On dirt you maximize the use of your rear brake. If something happens in front of you, you do not want to be squeezing the front brake, only the rear, if at all. You use the front brake either in ruts, or together with the rear brake when braking hard.Things I'm struggling with... On the roadrace track I cover the front brake with 2 fingers at nearly all times. This allows me to adjust my line if something changes in front of me. Is that necessary on a dirt bike? Should I be covering the rear brake or not at all?
Do not get into that trap! You have to look ahead, just like you do in road racing. Especially in rutted corners.Also, I'm having a hard time looking through corners. The corners on a dirt track are much more "interesting" than on asphalt and I REALLY want to look down at the front tire to make sure I'm not going to get caught on a rut or whatever.
Awesome Strider, I just picked up my EXR earlier this week. Saying these are fun machines is an understatement. Probably the best thing you can do right now is just make sure your suspension is dialed for you. I,m not sure what Alta recommends, but setting rear sag around 107mm, and adjusting your rebound speed is a good starting point. Because off road machines generally have 2-3 times the travel of road machines, you will probably have a slower rebound setting than your road race machines setups. My EXR is really soft for my weight, 245#, will be re-springing it. Probably not going to revalve though, the stock suspension is sweet for my kind of riding, mostly woods and desert riding at medium speeds, which I consider to be a middle of the pack B Rider pace. I know others have commented on it, just look where you going, not where you are at, I usually look 1 to 2 seconds in front of me on average.Hi everyone. Just to follow up on this thread. The pick-up went great. Shout out to Ajax Motorsports in OKC. Also, my son and I had our first lesson on Tuesday. The facility had an XC track and we spent most of our lesson there as it had a nice variety of terrain and turns and such for the instructor to get a feel for where we were.
One amazing thing about ebikes. There's one section where there's a gently hill then a short flat then steep hill. Invariably my son would stop after the first hill and stare at the steep one. I would stop next to him to encourage him up the hill. Without fail the bikes would start from a dead stop and just motor up the hill (he's on a Kuberg Cross). I also liked that I could creep to nearly a stop and just keep going again.
We caused a bit of a stir at the track. I let the track owner and his son ride my bike around a bit. Both came away very impressed and it was still in Map 1.
Things I'm struggling with... On the roadrace track I cover the front brake with 2 fingers at nearly all times. This allows me to adjust my line if something changes in front of me. Is that necessary on a dirt bike? Should I be covering the rear brake or not at all? Also, I'm having a hard time looking through corners. The corners on a dirt track are much more "interesting" than on ashpult and I REALLY want to look down at the front tire to make sure I'm not going to get caught on a rut or whatever.
It's fun to get back to basics like this and have the thrill of improving almost every lap vs on the road race track where my focus is on not making a mistake.
I am going to Amsoil 80/90W after my next ride.Don't forget the gear oil, that is stated for replacement at 2hrs. (In the 2017 manual).
FYI, our recommendation is to change the gearbox oil at 10 hours (any particles from the build will be flushed), then every 100 hours or once a year. Use an 80w-90 gear oil, what you would normally use in a ICE bike gearbox. Any 80w-90 or 80w-85 lubricant will be fine. It's basically a splash lubricant for the gear reduction.
