Gowow Ori (Cake Clone)
HadesOmega
San Jose
Some specs from their website
  • 73kg _ (160lbs)
    Vehicle Weight Design
    Lightweight and flexible
  • 100+ km
    Efficient Battery Life
    3.5 hours fast charging
  • 420Nm _
    Maximum Torque
    abundant power
  • 1900mm*780mm*1100mm
    Length/Width/Height
  • 280mm
    Ground Clearance
  • 100kg
    Maximum Load
  • 1275mm
    Wheel Base
  • 210mm
    Front-Wheel Travel
  • 210mm
    Rear-Wheel Travel
  • 9kw
    Peak Power
  • 420Nm
    Drive Wheel Torque
  • 420HO F: 13T R: 48T
    Transmission System
  • 55°@10km/h
    Climbing Angle
  • 100km/h
    Top Speed
  • Max endurance100km
    Endurance Mileage
  • Front and rear four-piston integrated forged calipers
    203*2.8 thickened discs
    Brakes
  • 3.5h 220V
    Charging Time
  • 6061 Forged Aluminum Alloy
    Carriage Frame
So it is a bit different than the Cake it has a gear reduction box instead of a direct drive. One thing I remember about the Cake is that it had a MONSTER rear sprocket because it was using a direct drive. It looks like it is using mountain bike suspension and brakes. I remember the Cake had motorcycle brakes and the rear brake was awful. The ori has brakes similar to a Sur Ron Light Bee. Looks like the battery is swappable as well.
Uses 21700 cells
Has gear box for primary drive
