fe501tired
- ca
I know one of the brand mousse's has a bouncier feel to them than the traditional ones that had a dead feeling I saw it on Slavin's racing you tube vid .
Would cutting it possibly affect wheel balance? Could I achieve the same effect with drilling holes in the mousse? I'd prefer to get at least another tire out of this mousse before tossing itToday I pulled the mousse out of an Varg EX rear wheel with the Michelin 140/80-18 Medium. Now the Michelin got a lot of volume, usually more than the Metzeler, the mousse has a cross section circumference of ~310mm and says "made in Austria" on it so I assume it is an X-Grip EH2 - seems too small to be an EH3.
Now if you look at the Nitro mousse sizing table Fitment Chart Search, the same 18-325 is shown both for the Metzler and Michelin that can be chosen stock for the Varg. Nevertheless for the JXE 140/80-18 the smaller 18-305 mousse is recommended. What does this mean? Most likely your mousse will be a tad too big for the JXE, but you can always cut out a piece and save for later when the mousse is worn. Will it be a perfect fit - no, but with mousse you never know until you try!
IMO balance isn't a concern here with the knobby tires usually seriously imbalanced anyway and speeds low. And it is hard to exactly drill the holes. Cutting is easier and as I said you keep the part for later to get more life out of the mousse. Actually you can also save the drilled out bits and re-insert them later, but it is just way more of a hassle. Get the new Prolock 360 instead and be done with the mousseWould cutting it possibly affect wheel balance? Could I achieve the same effect with drilling holes in the mousse? I'd prefer to get at least another tire out of this mousse before tossing it
ProLock 360 isn't available until MarchIMO balance isn't a concern here with the knobby tires usually seriously imbalanced anyway and speeds low. And it is hard to exactly drill the holes. Cutting is easier and as I said you keep the part for later to get more life out of the mousse. Actually you can also save the drilled out bits and re-insert them later, but it is just way more of a hassle. Get the new Prolock 360 instead and be done with the mousse
