Jack hammer varg forks
Osika
I have about 5 hours on it...love it but I have a half mile track ..no big jumps..but lots of choppy areas and rocky parts. Riding fast on those areas is harsh. I tried clickers all the way out but I think that is maybe worse than 18/15
( top/bottom) I had.
Will they soften up more or re-valve in order?
Tires 14/13.5 psi front/ rear.
Thanks!
Tom
markhamr
blaxlands creek australia
I havnt revalved mine
and i am not in the USA
main problem is it struggles under its own weight
im sure jbi can help you
not sure what your dealers like
bikes jet fast stock if you can afford the time out for arm pump surgery
i run a harder spring rate but i usually do for my weight im 64
like to run at stock for 85kg rider usual basic factory setup for most bikes
it looks smooth in there vids and on other bikes wearing there stickers
answer for chop is keep it wide open
there is posts on suspension here but in the end band aids
but suspension work is expensive
I live in au so our dollars worth shit when it comes to any mods
i think they said jbi where coming out with a kit might be available fitted through your dealer
my dealer races one i think it has racetech in it
