Bloak
- Ontario, Canada
As my MXR lower chain slider is showing wear, I started looking for alternatives.
I’ve been testing with KTM chain slider 79003053010. I also bought the KTM tie tod bolt (79004084000) but its to short, as not enough threads for the nut.
For the initial use, I tapped the Alta tie rod bolt (M8x1.25 if I remember correctly), added a spacer and bolted on the KTM slider.
Works well, no abnormal wear (3 motocross practice days on it so far)
As the slider is working well, I had a local machine shop fab up a new bolt for me, they made it a bit to long at both ends, so I will have that corrected.
Yesterday, test fitted rollers (Honda CRF450 rollers)
I may stick with the slider as it's working well, so the roller testing has been moved to a low priority.
