Maximum power the different Maps on the ALTA SM?
wwmotors
Bavaria Germany
Hello ALTA fans, Anyone an idea, what maximum power the different Maps on the ALTA SM have? I try to register my ALTA SM with 11KW max power as a lightweight Motorbike here in Germany, so that my doughter can drive it with 16 years of age! I hope, that may be Map 1 has only 11KW of poweroutput. Thanks for Your knowlegde!
wwmotors
Bavaria Germany
Thanks guys. Thats too much for our rules for 16 year olds in Germany. Any ideas how to put the power down to 11KW, what is according 15 hp? We have in Germany the follwing rules for battery driven vehicles: When the battery-motor system is not capable, to produce the enginepower for minimum 30min, then they test, whith what particular power the bike can run 30min! This power is then written into the papers. So for the ALTA with a 5,8 KW battery, this would be a calculated 11,6KW 30min power! Did anyone do this test until the battery is empty? Would be helpful. Thanks
