Finally, I'm working on a bike that needs several P-groups totally replaced due to a failure with the balancing system. These groups discharged way below the low voltage cutoff, one totally dead! You just can't wake them up and expect safe, reliable and adequate performance after that. Necessity is the mother of invention, so here we go . . . . . .
Developing a process for removing the bottom heat sink plate for cell removal was quite a nerve racking experience. If any two of the negative end series groups somehow manage to touch one will short out (full discharge) and that's never a good situation. Cutting the bad cells out should be easy, but I'll need to develop a more robust method (beyond the one/two wire bond fixes I already have) for re-establishing the electrical connections with fuse wire.
I already have fixes for all the top cover failures and if I'm successful I'll have battery pack repair knowledge and processes for everything EXCEPT total cell replacement. If you are in need of individual cell replacement keep an eye on this tread as I'll report progress. If you need any other Alta related repair simply email me at maxvonauto@aol.com.
Work in progress. Please don't ask for any DIY details, the process is too dangerous and I don't want your injury or burned down house to be on my conscious!
Instagram @maxvonauto
Instagram @radmotoart
