New Code 36 Issue MXR Vin 416
btreid23
Found a Multi-Tool to use.... although it looks like an older version 3.36.22.D
Only have a summary and dashboard.... no battery tab...
Let me know what you think...
Its the dealer version. Based on the indivitual module voltages - looks like Module 2 is a bit lower than the remaning modules (2mV roughly based on the algorithm which triggers the Code 36).
How often is the pack cycled?
btreid23
I run the battery down to blinking and then charge it back up every other month or so... I don't have any long rides.... so it takes awhile before I need a charge...
You need to clear the fault code and then cycle the pack since the Code 36 is a latched code (saved in the bikes ECU)
