Powertrain failed and making horrible sounds
Foss
Stark SME
Vestal, NY
Take the front sprocket off and let’s hear that powertrain. Use an high impact drill, it will spin right off easily.
It almost sounds like the sprocket is hitting the front chain slider…
Stark is going to want you to retake the video with the front sprocket off anyway… also they will want you to remove the gear cover exposing the gears for inspection. If the sound still remains it will be a new powertrain for sure.
Foss
Stark SME
Vestal, NY
Stark closed up my ticket never claiming the old motor back; safe to say I can keep it. So at some point I will dissemble mine and see if the bearings can be taken out easily. I’ll try and take photos of everything and maybe upgrade the bearings. Hopefully fix my existing noise and others could too providing a backup motor if needed.
If the motor is toast...I would not recommend saving it as if it is "repaired" and some how delaminates or separates it can cause potentially more damage in the motor housing. Curious to see how its built though....
Spike20
NC
Sent a message to Stark a few weeks ago they took a bit to get back to me saying the message went in their spam...
They were able to remote into the bike and said it would need a completely new powertrain. I took the bike back to the dealership I bought the bike from and Stark is sending them a new motor for it...
Was on asphalt when the motor locked up and messed my back tire up, so Stark said they would replace that and sent me an axe cause the nearest dealership to eastern NC is 2 1/2 hours away.
Just hoping those guys follow the video and fix it right lol.
This is the second time I read about a jammed rear wheel in a Varg.
It sounds pretty dangerous; when airborne, if I close the throttle with 100% regen braking, the front end of the bike dives; I guess that if the motor and the wheel stopped spinning suddenly, I would front flip. Also, those tracks in the weekend are pretty crowded and even if I am not jumping and that happens there is a non negligible possibility that someone will crash into me.
Spike20
NC
Yes this could’ve been a disaster!
UKLee
Happens with 2 strokes and even four strokes but then you have a clutch to pull in to unlock the wheel which could make all the differance.
What you've written is true and maybe our Vargs are still the most reliable motocross bikes out there, cosidering the crazy amount of maintenance needed by gas bikes and their low reliability.
I also add that you can stall a gas bike in the air (too much rear brake, fouling a plug, running out of fuel...) or you can unintentionally engage neutral and nosedive anyways.
Still, this problem is serious. I wonder whether it will become frequent as the bikes become older and older.
I hope that either the problem is something non common to all Vargs, like a bad batch of 100 motors, or that they find a solution. I've read that they did test some prototypes for hundreds of hours; it's so strange that we are already hearing about power units being replaced because of weird noises or stuck motors!
Honestly the only thing that I dislike about my bike is this worrisome possibility that the power unit may jam and the fact that I can only hope it won't happen to me.
I am very happy with my bike too. Like everything there are some things I don't like. My powerswitch failed after getting too much mud/dirt in it and my bike wouldn't power on. For enduro I think Stark will have to improve the sealing of the switch since crashes/tipovers into mud and dirt are common and though the switch is nice it is not well sealed.
Of course, there is the stock tubes and the oil drain plug but that has already been a worn out topic.:ricky:
fmjbrad
Orlando
You've won the lottery.
Looks like a just won the lottery with a 2023 mx 1.0, I was going about 100mph on 80hp and my motor locked up. I have no idea how I managed to keep the bike standing at that speed, was one hell of a death scare. Thankfully there was no one else on the road besides me and my buddy or I could've gotten hit by a car. Bike is still under warranty luckily so hopefully I can get a new powertrain soon.
Wow that is mighty lucky.
Somehow the faster you go the easier it is to keep a lockup straight.
Happened to me with about 100km/h in the mud on my 250 2 stroke that locked up the crankshaft bearing.
UKLee
Yes but pulling the clutch in quickly regains control and you can coast to a safe place, done it on 500 2 strokes on beach race mile long strights, not an option on a stark.
Not much of a transmission to seize up ( 2 gears ) I assume it is the actual motor that locks up ?
Yess but seizing the engine locks up the rear wheel wich is quite controleable in the straight. Especially in the sand.
I also experienced a gearbox lockup on a smaller 2 stroke, bearing of primairy axle that failed tilting the axle locking up both multiple gears at once as the crank-clutch transmission. That could happen to any bike as well. Needles to say the amount of mayhem in that engine was huge.
Bearings are often the unrecognized source of failures. They often give little indication of pending catastrophe and can fail at the most critical times.
