Overdub Happy
- USA
I’m 168lbs/76kg without gear got my EX with medium suspension. Preload in the shock was set when I picked up the bike. Riding loads of rock gardens and regular trails, I was finding the front end super harsh. Upon putting a zip tie on the fork, even in chill riding I was seeing about half of my suspension travel used up. When riding rougher trails/pushing harder, I was getting a little past half way of front travel. Opened everything up, not really any difference. Mid stroke did not match the spring IMO, felt like it just stopped once it hit mid stroke.
After installing the Slavens Mule Raven cartridge, same springs, 450cc/ml 5 weight fork oil, 4.25mm of spring preload, 20 clicks compression, 12 clicks rebound, I’m relieved of the super harsh feeling fork and I’m using all but 10 to 15cm of travel and now the shock feels harsh and deflecty. I’ve pulled out all the high speed compression from the shock and a click from low speed compression which is a bit better but still deflecting off rocks. I’ve also pulled out a couple of clicks of compression damping from the forks.
I was considering race tech gold valves but decided to go with Slavens mule due to it already being trail tuned and closed cartridge.
