SM conversion for the spring and summer months, then back to the dirt next winter ! (Now with Video ! )
jokerio
Menlo park, Ca
Waiting for my 14 tooth counter shaft sprocket, to :
1. Mellow the power delivery a little (but dont really need more top-end speed ! )
2. Tighten-up the chain a little (haven't cut the stock chain yet) I want to run the wheel-base as long as I can (initially, may adjust latter)
(These wheels are straight-off my 2024 Husq FS450)
I saw top speed about 80 mph with standard gearing, do you confirm?
Will be interested to see if it can sustain high power for longer times (compared to MX) without overheating or reducing power if there are some longish straights.
jokerio
Menlo park, Ca
I am running the FS450 rear sprocket, which is smaller (taller gearing, less teeth) than the Varg OE.
