mlbco
- Sunnyvale, CA
Maybe this has been mentioned before, but I just discovered that my MXR distance and speed readings are coming from the motor shaft and not the front wheel. This means the readings are WRONG if you change sprocket size, tire size, or let the rear wheel spin. I'm installing a Trail Tech Endurance 2 ride computer with front wheel sensor to overcome this issue.
Steve
Steve
