Stark Varg (6kWh) - 5 Hour Pony Express Strategy & 3kW Genny?
mbw479
Australia
Hey guys, I’ve got a 5-hour Teams Pony Express coming up and I’m taking the Varg 1.0 (6kWh battery). Looking for some real-world feedback on whether my charging setup will keep me in the race.
The Format:
  • Duration: 5 Hours total.
  • Laps: Approx. 35 minutes each.
  • Rotation: Going lap-for-lap with a teammate (Standard 1-on, 1-off).
  • Rest/Charge Window: Realistically ~30 minutes of "plug-in" time while my teammate is out.
The Setup:
  • Bike: Stark Varg 1.0 (6kWh).
  • Settings: Planning to run 45hp map with 30% Regen.
  • Terrain: Tight/technical. Not much wide-open throttle.
  • Charging: 3kW Generator. (Planning to set the app to ~2.4kW to avoid tripping the genny).
The Question: I’m estimating I'll use about 35-40% of the battery per lap, but I’m worried about the "battery bleed" over 5 hours.
  1. Based on a 2.6kW charge rate, will a 30-minute charge window recover enough to keep me out of limp mode for 4-5 laps?
  2. Has anyone run a similar format? Should I be dropping to a 35hp map from the start to survive the full 5 hours?
  3. Any tips for managing battery temp while fast-charging in 30°C+ humidity?
Cheers for any insight!
