Stark Varg DIY Trailside Repairs
leadingedge
I was thinking about this the other day, and I reckon it's necessary for us to have a good in-field "MacGyver" repair thread for Stark Vargs.
If anyone has any insight and trailside repair stories with solutions, please post them here.
As an example, one possible trailside repair I was thinking of:
Control switch failure - how to try get a EX, MX and SM switched on and select a mode (by just using the wires of the switch) when the switch is busted.
Please add ideas and trailside repair solutions to this thread.
You need to learn CAN Bus code, just like the morse code, and then "talk" to the VCU using the CAN low and high wire ;)
Seriously, if you break the control switch your only chance is a spare one - plain and simple.
Good to know, I was hoping that the wiring would be such to allow selection of a mode by shorting and opening one of the circuits.
The control switch module itself is no more than just switches as far as I can tell (I could be wrong) Does it not purely send an on/off switching signal for each button via the control wiring?
