- Temecula, CA
My in-depth review of the Stark Varg and Barcelona trip recap!
I hear you but its nice that it doesnt stick out like a hex nut does though. Good thing though is that you get all the tools you need in one little neat tool box.Thanks for taking the time to compile all that - being customer #1 is like having a part time job !
Bike looks to be very well engineered.
The only thing I can see that raises an eyebrow is the rather small size of the torx fitting to tighten the rear axle, guess they've got it figured out but I'll miss just stepping on my big crescent wrench to tighten that, all those years spent calibrating my right foot down the drain ...
Fred Flintstone ; meet George Jettson.
Yeah i talk about that on the video. Varg has less engine braking than the Alta and it seems to be speed sensitive, less at low speed vs high speed. Jumps much straighter with less nose down in the air, more like a gas bike. They really did a good job of mimicking the off throttle feel of a gas bike imo.Thanks for review question about jumping vs Alta on my mxr when I come into jumps on track I have to hold throttle steady up face through air and obv land on throttle if I left off in air on my Alta i endo like crazy sane as smashing rear brake on my yz. Not issue on Alta you just need to remember to not let off. How is stark in air ? Is it more like a gas bike hit jumps hard and you’re good it’s hard to hear motor. I kno biggest thing took me getting used to was jumping my Alta Vs gas & almost going OTB first time I forget to hold steady throttle in air. I’d love to hear you’re feedback. Thanks for great review.
That’s awesome I’m so pumped to hear that. That’s my biggest gripe w Alta mxr remembering to never let off in the air. Sounds like stark fixed all Alta shortcomings which is awesome.Yeah i talk about that on the video. Varg has less engine braking than the Alta and it seems to be speed sensitive, less at low speed vs high speed. Jumps much straighter with less nose down in the air, more like a gas bike. They really did a good job of mimicking the off throttle feel of a gas bike imo.
That said, you can adjust it to whatever your liking is.
LOVE all the details !!!My in-depth review of the Stark Varg and Barcelona trip recap!
That's my plan to try & train myself to the LHRB while still leaving the foot brake operational.
For anyone in doubt about the rear brake option.
You could also do a combined rear foot brake and left hand brake.
The only special part needed is a insert for the foot brake reservoir.
The Alta LHRB uses a stock KTM/Brembo clutch master, and it works fine.I already have a spare Brembo left side hydraulic clutch master, but those clutch masters don't hold enough fluid to allow for the wearing down of the brake pads.
What type of adapter is needed on the rear Brembo system to have both foot brake & LHRB operational ?
Guessing I'll also need a custom brake line as well ?
Wow, they are selling the rear caliper for that hand brake too?!!It's Formula Brakes. They have catalogs at their site, but I couldn't find the piston size for the FM10109-20 Stark unit above.
Owner's Review Stark Varg vs Alta MXR | Stark Varg Reviews | 0 | ||
D | Stark Varg Frame and Motor Guards | Stark Varg -- Discussion | 0 | |
N | Has anyone from CA used dirtlegal.com for Stark Varg? | Stark Varg -- Discussion | 2 |
