Stark Varg Front wheel misaligned
pospecd
Czech Republic
I fell down in a rut while going very slow and my front end got out of place. I tried all the methods i know about ( loosening triple clamp bolts and pinch bolts, spining the wheel and grabing the brake, compresing the forks) but i still cant get the front wheel to be aligned with the front fender and it doesnt feel right while riding it. Any tips? Sorry for my english. Thanks
UKLee
This does seem to happen quite easily on the stark, just pull up to a tree or gate post and put the side of your front tyre against it and pull on the handlebars it usually moves quite easily even with everything done up to the correct torque.
I don't think this is the problem you discribe but also the bars can move on the rubbers in the top yoke, on most bikes it is quite easy to see they are not in line but with the stark phone holder not so easy to see it. Slackening the nuts off on the mounts and the bar clamps then re tightening should put it back stright but often pulling it to the lock stop and pulling on the bars is enough.
Other option is don't fall off:D
Captblues
Florida
Any dirt bike is prone to this issue, is designed keep you from braking components or bending parts. I had this happened before, and the way to fix it:
1- docking stations bolts losen.
2- the stem bolt losen and realigned then tighten to 35Nm
3- tighten and realign handle bars to 30Nm
4- losen the axle lock bolt and clamp bolt
5- losen triple clamps and retighten to specs. ( Nm listed on the clamp)
6- tightened the axle lock bolt to 35Nm
7- spin front tire and apply max brake multiple times to realign front tire and brakes.
8- tightened the axle clamp bolt to 15Nm
after this everything should be aligned.
