Jake
- Washington State
I have seen a lot of unanswered questions about the difference between the MX and the EX. After watching about 4 hours of interviews with Anton Wass, here is what I heard:
Stark Varg MX Vs EX
Stark Varg MX Vs EX
- EX is Street Legal in most US states
- EX has Different Battery Connectors not compatible with MX
- 20% more range, higher capacity more efficient (Deeper Discharge) Cells
- More efficient motor (software)
- DOT tires are heavier
- 4th Gen Power Tubes aren’t complete junk
- Kickstand not included in weight of MX but is on the EX
- Longer Bracket for Kickstand
- DOT Rims
- Lights, Horn, Blinkers
- Integrated Map Switch for light, blinkers, horn and low beam/high beam
- Brake light switches on master cylinders
- Slightly less fork travel
- Slightly lower Seat Height (even though spec sheet says it’s higher)
- More vertical and horizontal frame compliance (flex)
- Same Frame Geometry
- Improved Swing Arm (Lighter and more flex) with more tire clearance
- Improved Chain Guide
- Higher torque due to sprocket ratio
- Super moto and smaller size bikes on the horizon
- EX has an "Arkenstone" Phone (developed by Stark) and new software that allows:
- GPS Mapping
- Adjustable Power Curve
- Locks the Bike with PIN if desired
