Switch off light on Varg EX
JJ2
I would like to be able to switch the lights on and off on the Stark Varg EX. Unfortunately, due to EU regulations, the daytime running lights must be permanently lit.
The connecting cable is a 5-pin HIGO plug, three pins are for the indicator and two thicker pins are for the light.
Has anyone already an idea?
The simplest way would be to acquire compatible male and female connectors, splice them together with a switch interrupting the appropriate wire(s).
When you activate high beam, does the low beam turn off or are both lit at the same time? Obviously the most convenient way would be to turn it off via an app setting, so maybe there is something hidden in the EX app. Do the US bikes behave in the same way? On ICE bikes you could often use the US switches to accomplish this. Last but no least, if you have to tap into the wires I'd do it on the headlight side. Either install your own connectors AFTER the Stark connector to splice in a switch or just find the ground wire directly to the headlight and tap in there.
JJ2
the plug is already connected to 12V before the headlight, so everything that has to do with the headlight and the indicator is operated with 12V.
