Has anyone had this fault? I have just replaced the motor, all wiring is fine, the coolant has been replaced, there is a noise coming from the pump but I can’t tell if it is pumping.
Edit: Bleed the cooling system as per a pdf on the support section of the stark website, fault has cleared, bike is fine.
