No problem, I am glad to explain. Normally the dynos measure the HP that is required to spin the dyno's drum (HP at the rear wheel). They also measure the RPM by reading a spark plug wire. You can already plot the HP vs RPM accurately.How is torque at the motor measured on the dyno?
The stock front sprocket on the MXR is already 12. Are you asking what would happen if you install a smaller or a larger front sprocket?How would dropping the front sprocket on the MXR to 12 in Map 3 impact the results and efficacy below 30MPH as well as battery life versus riding in Map 4? I utilize Map 3 for the majority of my track riding, but feel it is under-powered down low compared to my KX 450F and hitting jumps out of a corner is still a concern as I am still developing confidence on the Alta.
A smaller front sprocket will feel more like riding in the 1st gear where a second is needed. More wheelspin at low speed, then it will top out and become the same as before. You will still have only 37hp max, you will just waste more energy to wheelspin.Thank you and yes, I meant to state smaller on the front sprocket. The only area I feel the Alta is under powered is coming out of corners with a short run to a large (50-plus foot) jump. I only have an hour on the machine, so still trying to adjust to the torque versus harder hit of a gas engine. Map 3 works well in all areas of a track inclusive of straights, sandy areas and jumps except for short runs out of a corner for larger jumps.
A dealer suggested reducing the size of the front sprocket, thus getting the bike into the "meat" of the power sooner instead of running in Map 4 which will very quickly diminish the battery charge.
I would disagree with the idea that map 4 will get you much less range. It's all about that right wrist. Sure, if you go around blowing off the rear tire the whole time then yes. I have been using map 4 pretty much exclusively at this point.A dealer suggested reducing the size of the front sprocket, thus getting the bike into the "meat" of the power sooner instead of running in Map 4 which will very quickly diminish the battery charge.
Precisely!Therefore, Map 4, by itself, does not use more energy than Map 1. If you rode the bike around in Map 4 the same way your rode it in Map 1 you will use the same energy.
Precisely!
I had to Google this one because I did not understand what the assumptions had to be for this to be true.So here's a bit of trivia regarding EVs. The rate of acceleration does not affect the amount of energy needed (Assuming no wheelspin). Unlike an ICE where accelerating rapidly requires revving higher with larger throttle openings that consumes more fuel, you do not consume more energy accelerating an EV quickly vs accelerating slowly.
Resistance goes down as heat goes up. Tesla has a max performance mode that actually heats up the batteries. This is not good for the health of the batteries which is why the bike limits power when the batteries get hot.And the faster you accelerate, the more quickly you use the energy stored in the battery cells, the more the battery pack heats up, the higher the inefficiencies of the electrical system. I had to google this one too.
__________
_ ------------
_ -
_ -
Hurry up! I thought you were an Altaracer already!I am selling my ICE bikes now, looking to buy a used Alta MXR.
F | 2017 Alta Redshift MXR - For Sale | Alta Redshift -- Discussion | 0 | |
P | Alta redshift mxr battery error | Battery Repair | 0 | |
C | 2019 Alta Redshift MXR code 36 in Fort Collins, CO | Battery Repair | 4 |
