Brake light not working from back brake
Wnuudiction
Maui
Haven’t gotten into it yet, but just checking if anyone has had any issues that they have worked out. I see there is a connection under the motor which I’ll disconnect and spray electrical cleaner in. I don’t know if there is a pressure adjustment on these brembos. Figured I’d ask before I make more work for myself. Front brake works fine.
Thanks
Wnuudiction
Maui
You said connection under the motor...did you mean the brake pressure switch on the Brembo master cylinder? Also are your turn signals working?
The one to the sensor on the master cylinder. The front brake, turn signals work. The rear brake used to until a couple weeks ago.
Check the connection between the sensor and harness. It's a separate harness for the subframe. Since the turn signals are working sounds like a loose contact.
