Coolant Cap O-Ring
effinsiok
PNW
Does anyone know what size and material the o-ring is that's used on the coolant cap? Mine is all cracked around the edges.
Do you have an older Alta or a newer Alta?
The older bikes used a plastic coolant cap (M22)
The R bikes got the red anodized coolant cap which came with this O-ring: O-RING, 19.3MM ID, 2.2MM X-SECTION, NITRILE which the closest is this on McMaster: McMaster-Carr
effinsiok
PNW
I have an older MX (0035) with the plastic coolant cap.
effinsiok
PNW
There isnt a o-ring that came with that part. It was a single piece.
Interesting, mine has an o-ring fitted under the head of the cap/plug, but there isn't a face or radial groove for it to sit in. It sort just gets squished between the head of the cap/plug and the aluminum frame. Should I take it off?
MX35 is a pretty early bike, would you be able to take a picture of the coolant cap along with the coolant port near the deltawing?
Once I see that picture I can clearly discern between what was used.
effinsiok
PNW
Here are the pics, let me know if I misunderstood what you were asking for (I’m not sure how to rotate them from my phone)
