- Lake Havasu City, AZ
I think I should re-post the DIY LHRB recipe, which is buried on Page 6 of The Alta Factory LHRB thread.
Here is the recipe:
1) Brembo clutch 9mm master cylinder KTM P/N 79202030044 from the 2017 KTM SX-F 250/350
2) Clutch hose KTM P/N 60032063100 from the 2014+ KTM Adventure (must straighten by 45deg at your own risk)
3) Clake slave cylinder adapter SLR – Pedal Master Cylinder Adapter Kit. Make sure the Clake adapter you receive has a 51.5mm overall length.
The hose has a 90deg bend near the banjo fitting. Ideally there should be no bend, although a small bend is okay. I put it in a vice and straightened it to only about 45 degree bend. That worked, until I installed it and then out of curiosity decided to straighten it a bit more. Well, it broke. Cannot straighten it more than 45 degrees. I bought another hose, straightened it only up to a 45 degree angle, and it is working now.
I have had my MXR out a few times, and the LHRB is working okay. It is not quite powerful for routine brake slides, but it works as well as any LHRB that I have tried.
The cost -- about $290 total with shipping.
Here is the recipe:
