Marko_Flux
- Slovenija
Thanks, so first thing's first, here's the video of the trail ride range test:
We strive to be the EV company that's honest with their customers.
Having a modular battery is doable, but everything in life is a compromise. Dual battery means running them in parallel, so you'll have double the cells in series, meaning a much more expensive BMS combined, compared to a single battery with equal specs. There's ofc also considerations for extra weight with doubling housings, fixtures etc.
Our team's background is in aerospace, so we have a competitive advantage in the higher performance spectrum. There's only one competitor there today, while on the light off-roader side there's a bunch (KTM, Surron, Dust?, etc). Some of those are already good, others can be made better with a suspension swap. Components are readily available off-the-shelf. It seems advantages there would be razor thin and the Asians can beat us on price. There would be some willing to pay a premium for more, but generally a beginner/playbike is much more price sensitive than something like the Varg, where you want the best. At lower power levels, a high voltage system's cons start to outweigh the pros. Those are my thoughts at least.
The Primo has a swappable battery, you can yank it out from the side. It's not optimised right now with a quick release system, but you just undo the bolts, detach 2 connectors and out it goes.
My question for you guys is would you be buying a second battery at a €6-7k price point? Or would a higher range and faster charging solve the shortcomings in a better way?
