- Lake Havasu City, AZ
That was going to be my offer, except I couldn't offer the whole Feng shui part. I'm afraid I failed hippy studies 101 in engineering school.Step #1: Send me your bike so I can look at it for a few weeks, maybe ride around a bit, and generally get in touch with how the hose “feels” like being routed. Get the whole feng shui vibe thing going, balance the battery, contemplate the rightness of the universe. Generally balance the go and the stop energies. Then I can send it back and give my recommendation on correct routing. Because I want to help my good AOF bud with his dilemma. It’s the least I could do.
I could be wrong, but you might have to get a longer front brake line.
I was thinking about this possibility. But with my display remaining on top of the handlebars, I should have a plenty of room behind the headlight. If I make sure the line doesn't catch onto any hooks, I think I can make it work.I believe the SM,EX,EXR has a longer front brake line than the MX/MXR. They were actually different Alta part numbers. I don't think the MXR brake line will have enough slack to route behind and above the headlight assembly like the one on the EX/EXR does. I could be wrong, but you might have to get a longer front brake line.
Here's how the EXR looks:
Confirmed. Indeed, longer by almost a foot. View attachment 1605I believe the SM,EX,EXR has a longer front brake line than the MX/MXR.
Makes sense! All the switches are probably low-voltage switches that alert the ACM.#3 and #4 look like they go into the open pigtails from the ACM. Not sure about the application, those are low voltage (3-5v) pins. Maybe some of the accessories only need 3-5 volts?
I see you re-routed your stock MX/MXR front brake hose because you installed a big front brake disk. Makes sense. Why did you have to mess with wheel spacers?This is my SM conversion. I went the outside around with the brakeline, as You can see on the picture. I took a brakeadapter from KTM, to fit it to the 320mm brakedisc. The wheelspacers i had to measure myself, because this is not like KTM measurements. I went in the cartinghall in cold german winter with the bike. It works pretty good and i was faster than with th 250 rentalbikes there! But I have one problem: The mapping always jumpes back to map 1, no matter what map i start with. Anyone experienced the same problem? What could be the reason for? This problem never occured with the MX wheelset!
M | New bike help needed | Stark Varg -- Discussion | 14 | |
how to put the bike on a stand without help from others | Stark Varg -- Discussion | 18 | ||
General Help problem posting pictures in private messages | General Discussion | 3 |
