- Lake Havasu City, AZ
Recently I discovered that, if my Tesla died on a freeway, I have no ability to charge it from a generator because my generators do not have a bonded neutral.I think this would work....would appreciate if someone could confirm:
https://www.amazon.com/Leviton-515P...5P708Y/ref=psdc_6396120011_t1_B00FL51TUE?th=1
"Leviton 515PV 15 Amp, 125 Volt, Grounding Plug, Yellow"
Also, what gauge wire would you use to connect the Ground plug to the neutral plug? (or does the gauge of the wire not matter).
Happy Monday.....
I googled and watched some YouTube, and almost bought this thing from Amazon, but then made a similar plug myself. Just a jumper wire from Neutral to Ground. Generators usually have two or more outlets, so you put this plug in one, and then the other will appear to be grounded to the Tesla.
I think the gauge does not matter. There should not be much current going through that wire.
