KTM65 Electric Conversion
Having owned several Altas and built a couple Alta based conversions (see Honda ElectroGrom and ElectroCRGshifterKart) I decided to build something electric that was NOT based on the Alta platform/running gear.
Along with my partner in crime (Instagram Electrtrobraap (@electro_and_co) we decided to use commercially available components to replace the extremely rare and expensive Alta parts. We sourced the motor, motor controller, battery management system (BMS), throttle and display from China.
This took quite the effort searching the internet for leads to good components but luckily there's a rather large community of electric "gearheads" with a wealth of knowledge and experience along these same lines. Of course, it still boiled down to selecting the proper component for out specific application, but at least it helped focus us in the right direction. Of course, ordering parts directly from China is another story (and post).
Upon receipt of the various parts it was becoming apparent that China can produce some well designed and well built components! I was impressed.
The BMS, for example, was not only well built but had features my Alta BMS (and I) wished it had! Truly amazing for the price. However, don't get me started regarding user manual and/or documentation.
The motor we selected is very nice, it's the smallest, lightest, and most capable motor we could find ANYWHERE, regardless of price. Truly amazing.
The motor controller looks to be a very robust and capable unit as well. It's not the most sophisticated controller, but it's programable where it counts and has 4 user configurable speed maps selectable on the fly using the supplied handlebar throttle/switch.
The only item we couldn't find to meet our requirements was the battery pack. Oh, although there's plenty of options available they're all mostly junk. And although the quality of build and components gets better outside of China we still couldn't find anything even close to what we wanted.
What we demanded was cutting edge performance, basically a mini version of the highly recognized Alta pack. Very small and lightweight yet powerful with good capacity (range) yet built to take the abuse of constant off road use. Class leading in terms of power, size and capacity densities. The only reasonable choice is a pack that incorporates the small cylindrical 18650 type Li-Ion batteries (cells) from Sony, Panasonic or LG.
Does anyone make such a super pack? The answer is NO they don't, for any price. So I designed and built my own and incorporated some design features not even Alta could match! Based on the exact same cells in the Alta from Panasonic my pack uses 100% COPPER interconnects, not nickel plated tin or alum. I also literally "weld" those copper interconnects to the dozens of cells using a pulsed arc (like micro Tig) process, not cheap spot welding. The result is a pack that beats the Alta in all the important performance metrics!
Why copper, why pulse arc? There's hundreds of cells inside the pack, each requiring electrical connection to one another. That equates to literally over a thousand tiny welds. The electrical resistance of those thousand welds adds up fast! Copper has the least electrical resistance of any metal (not including gold) and results in lower internal pack resistance and better performance. Simple as that. Why doesn't everyone use copper? It's also the most difficult metal to weld so you need expensive equipment and a very labor intensive process so it doesn't lend itself to mass production.
The roller - We picked a small frame bike for our first prototype, a KTM 65. With the advent of the new electric KTM and Husky it's becoming clear that electric is gaining popularity among moto dads/moms and kids alike. It's a great combination with lots of benefits. In addition, the motor/controller combination that we found most desirable had the HP/torque capability to match this class of bike while allowing ample performance headroom to satisfy the adult mini rider as well.
The integration - While the bike didn't exactly assemble itself it was surprising how easy it was to locate and secure the major components like the motor, controller and BMS. Nothing the average guy couldn't do with basic tools. Of course, the battery pack was the biggest challenge but it too eventually integrated very nicely.
The result is what you see below. I still need to completely weatherproof all the electronics and pack but it's a 100% functioning prototype right now. The weight is 140lbs, about 10lbs over stock (with some gas). The weight distribution is about 48/52, right in the ballpark. Top performance right now is regulated but about 70% of the max possible, 10.5HP and 33 ft/lbs. While the HP number isn't spectacular the torque is in the F450 range! It makes for brisk acceleration and unlimited hill climbing potential. Max speed about 50 mph. Of course it can be turned down to match the rider's skill using the map switch but for now we're having too much fun in map 4!
Incredible work, Mark! Have you had a chance to compare it directly to a KTM 65 gas bike? Looks like the KTM 65 produces 13-15hp and 9-10ftlb torque. I bet your bike out accelerates a KTM 65, but suffers at higher speeds, kind of like our Altas when compared to a 350 or 450.
ElectroBraap
California
Nice post about our build @Mark911! It’s been a long journey already and yet so much still to do! From theory, to idea, to concept art, to hours of part sourcing, hours of debating, endless planning, initial construction, and now testing...I love it every minute! Can we do it all again when we are done with this one!? *dead serious*
I imagined this project from the beginning as a 110 pit bike killer with the potential to keep up on the race track. I’m stoked that we have been able to get to a point now where we know the idea has roots in reality!
I hope you all like it! If you want to stay up to date with the most recent developments with this project check out our new Instagram @electro_and_co .
Due to social distancing making videos has been tough but I think I have enough footage from mark to whip something together soon. So, don’t forget to keep my channel in your brain holes for the foreseeable future! 😂 That’s where all the juicy videos will eventually surface!
Any comments or questions are welcomed!
Thanks Everyone,
Electro
San Ramon, CA
Sweet! I see you are still attached to the gigantic rear sprocket, though. No chance to downsize that?
ElectroBraap
California
Now if it only had 5 more hp and weighed 50lb less, I think you might be able to make it work....:p
50lbs!? 😵😂 I wish haha! We came in about 10lbs more than the oem spec for a 65 as @Mark911 mentioned. With the current battery design, mass reduction is not possible unfortunately (not significantly anyways).
The 65 is about the size of a 110 so I think it will make a great pitbike. We have yet to see how a kid will be able to throw it around on a track. Hopefully we can test that sooner than later! 🤞
Electro
Redwolf
My dog thinks I'm cool
Brinnon, Wa.
lol, I'm not sure if I am just trying too hard, or if you guys haven't read enough layman's Expert reviews of every new motorcycle ever produced... the unanimous verdict is always that it just needs a couple more HP, and lose a few lbs, and it would be the perfect bike for them to buy.
My attempt at humor aside, that is a really cool build you guys did there, really looks cool!
ElectroBraap
California
Oooooo that makes so much more sense haha. I took it in a joking playful manner but didn’t connect the dots. *doh* In hindsight that’s quite funny! 😂
Thanks man! We try! @Mark911 has done some amazing work on this bad boi.
Don't forget, it needs to be at least 50% cheaper than whatever the final price may be.
VINSANITY
Can you provide a link and some information / specs etc. for the electric motor you purchased - thanks
'Lots of battery pack questions. Here's a challenge, sorta. Our pack is around 1.81Kwh, 72v Nominal, and we're running around 125 amps right now. Can you calculate (SWAG, scientific wild ass guess) what cell configuration we're using?
VINSANITY
Assuming your 18650 cells are 3.6 V & 2.6 amps for each cell I calculate you battery is 20 S (series) & 10 P (parallel)
