- Temecula, CA
Thanks, I tried a couple of the older aebins from the zip files, neither worked. They are all newer than bcu 2.15.1. I hope to find someone who could share 2.15.1.aebin
Firmware Downloads (All Released Versions)
Who has the bootloader unlock codes? Did Alta have to request them from the pcba manufacturers on some kind of token basis? I’m assuming the pcba’s were tested at the io level before delivery...Every pcba has a bootloader. So unless your playing with the parts...I dont see the rationalization of your post.
(For the sake of the OP, you should take your comments to another post.)
I wonder how many inoperable bikes are out there. Last time I checked Liquid had 8 motor/bulkhead assemblies available. It sounds like motophyllic has one and I obviously have one.
That makes at least ten possible additional Altas to add to the finite population. Finding more bikes will only increase the value of finding a solution to the software issues.
I was hoping BRP would offer their electric go cart or electric street bike with electronics and drivetrain derived from the Alta and Alta owners would be able to buy compatible parts from them, but so far those vehicles are just prototypes.There may be mechanical parts but there are not enough electronics to go around....
Of I could only get a grbl of the board/s id give it a shot. Probably helps to have a working unit.
Not “gerber”. He clearly said “gerbil”. Gerbils are integral to the design and manufacture of small integrated circuits, since they have tiny little hands that can work on intricate electronics. They can hold the little soldering irons and TIG welders necessary to make most of our modern electronic equipment. Gerbils are to electronics what squirrels once were to mechanical horsepower, at least before dinosaur juice was discovered. Gerbils are the main reason China dominates the current electronics market, since they have access to an army of Mongolian gerbils. Sure, we have chipmunks in the US, but they have never been certified for electronic work, and they tend to stuff the components in their cheeks. OSHA has a shit-fit about keeping tools and heavy metals in your mouth during the manufacturing process. They can get away with that kind of thing in Chyna, of course, which gives them another economic advantage in the high-tech market.I'm an electronics layman, i'm starting to gather that you are not? I have read the term "gerber" in conjunction with circuit board design? Is this what your post pertains to? All I know about gerber is the baby food and the sweet pocket knife I have
S | Protective case for charger. | Chargers, Generators, Inverters | 3 | |
S | Chain rubbing on case. | General Discussion | 3 | |
G | Charging question-bike won't take a charge | Stark Varg -- Discussion | 3 |
