Wnuudiction
- Maui
I got this fender eliminator. It comes with no instructions. There apears to be a resister, I could trial and error but figured a more experienced member put it on already.
OK thanks for the tip, cringe a little at wasting that 3.7 or 4.7 watts but it's tiny.
I had a similar issue with the NCR kit on my SM, but it only effected the taillight, the brake light and turn signals worked fine. I contacted NCR, they looked into it, and discovered the new firmware feature described above: the ECU load tests the circuit and shuts it off if it doesn't see enough load. Justin at NCR sent me a new lens unit with a resistor installed, and everything is working fine now that I've installed it.
Yeah, same here, Justin was very helpful through the whole troubleshooting process. Now just waiting for the resistors in the mail.I had a similar issue with the NCR kit on my SM, but it only effected the taillight, the brake light and turn signals worked fine. I contacted NCR, they looked into it, and discovered the new firmware feature described above: the ECU load tests the circuit and shuts it off if it doesn't see enough load. Justin at NCR sent me a new lens unit with a resistor installed, and everything is working fine now that I've installed it.
I can upload some pics of mine laterWe would love to see some pictures of the NRC equipped Redshift.
Want to buy NRC fender eliminator | General Discussion | 0 | ||
KTM Front Fender mod is a must! | Pictures | 8 | ||
SM vs MXR (Rear fender & subframe) | Accessories, Lights, Bling, Plastic | 12 |
