Rekluse LHRB brake line
privateer703
AOF Addict
Altoona, PA
Does anyone know where I could get a replacement brake line for the Rekluse LHRB? I smashed the line and I'm pretty sure the inner steel liner is punctured and the fluid is leaking into the rubber sleeve. This could be a standard brake line but I just wanted to check to see if anyone knows for sure.
privateer703
AOF Addict
Altoona, PA
I was able to find the part on Rekluse Parts Fiche. 745-014A - $105 !! I wonder if I could buy any brake line and cut the lever side banjo fitting off to use with the Rekluse lever fitting. Would save me 50%.
Yeah, common stuff is getting pretty expensive.
I would still call them. Their support engineers might be nice enough to answer that question too.
standbyu
Portland
In Portland (Antifa capital of the world) there's a company that builds replacement hydraulic lines called "Oil Filter Service" . They can make up anything you want. Perhaps in your city there is similar outfit. These brake lines are similar to marine trim and steering lines. Harley shops have some too.
