Redwolf
My dog thinks I'm cool
- Brinnon, Wa.
+1, this is a great place to picture sharing.I like where this thread is going! Better find some more pic opportunities, challenge accepted!
Where you at Oded? Where's this picture taken?going deep off road with the EX
VERY SCENIC!!!!
Thanks MP, it grips too well in certain situations and pushes the front a bit. Its the Moto Z hybrid trials tire with a MX tire casing. This is the 120/100x18 and it is BIG. I like the tire and will run it again, the next one will be the 110/100x18 though.I like your rear tire. Looks like it grips good!
When I threw on the new tire, I also changed my gearing from 13/53T to 12/52T. Whatever mechanical advantage I picked up by going the slightly lower gear ratio (about 6%) was made up by the increased circumference of the tire. Its as tall as my front tire. This next year, I will duplicate some rides I had with the stock tire and let you know if range was affected. But my gut is telling me no.Thanks for the info. That’s exactly what I was looking for. Just wondering, did it hurt your range and why would you switch the size. I was thinking the biggest possible for better traction where I ride with a lot of rocks, logs, and basically trials country.
D | Alta EXR is finally due for a new chain and sprocket set | Wheels, Tires, Sprockets, Chains | 6 | |
Alternative chainslider for MXR/EXR | Resources | 1 | ||
J | Redshift mx conversion to exr | Sources for Replacement Parts | 0 |
