Where is the flasher ?
Trialsman
Pittsburgh
I have two EXRs and just replaced the turn signals on the one. They are barely flashing, probably due to the ones I took off were LED and the new ones are not. I assume the flasher needs switched over, but where is it? Thanks for the help.
There is no flasher/relay in the Alta harness, its managed by the ACM. If your going to use LEDs you have to add a resistor inline to slow them down.
Trialsman
Pittsburgh
Thanks Rashid510, I had LEDs with the resistors and removed both to put on some incandescent ones I had in the drawer. Now the dsh light flashes quickly and the bulbs barely light up and are a quick cadence. Any ideas?
HadesOmega
San Jose
Hmm New Rage Cycles selling a blinker kit for the front of the redshift and according to their instructions you need a 22ohm resistor
