It's been discussed that there's just not enough room between the shock and the rear subsection to incorporate a proper bladder system.  There's just so much length and although going "fatter" might work with a piston type reservoir a true bladder needs to collapse radially, not axially, so you need length.   So, you could hog out the fender or deform it with heat but you'll probably still have a relatively bad aspect ratio for a bladder.   So I decided to solve the problem by incorporating a KYB bladder system onto one of my stock Alta WP shocks.  It's been too wet (yes, in SoCal!) to test but it should work just fine.
